im Axle Specialists
Thread Tools
Old 14-11-2009   #1
Weird front end problem
Hi, After going over a large speed bump (slowly and carefully) I've developed a strange front end problem. It's difficult to explain and I'm going to sound really flakey now but it feels weird through the clutch as you pulll away. You can also feel it when you brake to a standstill. There is no noise but it feels like the engine isn't connected properly to something important. My best guesses would be engine or transmission mounts or possibly suspension bushings. I'd have thought broken mounts would make some clunking noise..? Sorry about the crappy explanation but I can't think of another way of describing it. Any ideas? Nick
Nick600 is offline Reply With Quote Quote
Old 14-11-2009   #2
Trader Rating: 5
fingers99 has donated!
Re: Weird front end problem
Could well be a mount. Need to get under and take a look.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 22-11-2009   #3
While changing the clutch I had a good look at the mounts and suspension bushings and they all look OK. The rear gearbox mount had a lot of flex in it when the plastic bush was removed, is that normal? I guess this problem could have been a symptom of the clutch packing up as the issue is not there at the moment. Fingers crossed it's gone for good.
Old 22-11-2009   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
If you are refering to the plastic bit in the middle of mount, it shouldn't come out.
This might be your problem.
SPD
Old 22-11-2009   #5
Trader Rating: 5
You might check that it's been fitted the right way round -- shiney side should be up.
M12 fund 20
Old 22-11-2009   #6
Ah, it just fell out so looks like that might be the problem. Off to Fiat again!
Old 22-11-2009   #7
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by Nick600 View Post
Made of money?
Why not try Fluffy
SPD
Old 22-11-2009   #8
I'll try Fluffy, I was just being impatient, certainly not made of money...I spend every last penny on my cars, my other car is a BMW 850 money pit, but I love both of them really
The plastic bit may be on the wrong way round as it's rattling like a bstod on decelleration. I'll live with it to the weekend, my wife is losing her sense of humour.
Old 22-11-2009   #9
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Thank your lucky stars that she at least has one to loose!
SPD
Thanks Nick600 thanked for this post
Old 23-11-2009   #10
Turned the plastic thing around and the rattling has gone.
I had another look at the mount and it's totally shagged, I better change it before it gives out.
Thanks for your help chaps, I appreciate it. Nick
Old 23-11-2009   #11
Trader Rating: 5
If you have any knocking about, it may just be worthwhile filling it with Sikkaflex, leave it to cure off the car, and then bolt it up.
M12 fund 20
Old 07-12-2009   #12
I put on a new rear gearbox mount at the weekend and all my woes have now gone. The old mount was hanging onto life by a thread and was almost ready to give up entirely. Got the mount from shop4parts for about 20 all in. It's an easy job to fit, you have to remove the entire bracket then bolt the new mount onto the bracket off the car otherwise you can't tighten it down as it has no captive bolt. Other than that, piece of cake.
Thread Tools
(T) Cinquecento Front End Questions... Shunted Up Front steve38 Cinquecento / Seicento 6 03-06-2008 14:03
help weird whineing noise coming from front of the car sjones280982 Newbie Central 4 24-05-2008 16:21
(T) A weird problem... Sonic74205 Cinquecento / Seicento 2 12-02-2007 15:51
Weird Problem.... jdillon Lets Talk FIAT 1 11-01-2005 11:58
(T) A weird problem The younger modder Cinquecento / Seicento 2 08-06-2004 18:18
