Old 02-08-2009   #1
fuel tank removal
Hi, hope someone can help. How do I remove the petrol tank from a seicento sporting? Going to the scrap yard tommorow and could use any advice. Oh... it's a W reg if thats any help. Many Thanks
Job13 is offline Reply With Quote Quote
Old 02-08-2009   #2
Speed Camera Tester
ilsonemo's Avatar
ilsonemo has donated!
Re: fuel tank removal
i have a cinq, and i started by:
1. reversing it up onto ramps
2. drain the tank
3. removed the bottom of the rear seat for ease
4. removed metal panel protecting fuel pump
5. removed the pipes and plugs to the tank (leaving the fuel pump in)
6. then went underneith the car and removed pipes (just held on by clamps easy removed)
7. then i attempted to unbolt it, but all but one bolt snapped (there are two bolts and the rear of the tank either side and two bolts at the front of the tank in the centre, one was holding my exhaust heat sheild)
optional: you can lower/remove your exhaust for ease of removing
(all i did is remove it of its rubbers and lowered it to the floor)
8. remove the tank
If your bolts snapped like mine, you can drill them out and use your own nuts bolts and washers
hope that helps
Quote Originally Posted by Charnwood Fox View Post
Only if you've got a trump-shuffler standing behind you when you are bent over the engine bay.
ilsonemo is offline Reply With Quote Quote
Old 02-08-2009   #3
Speed Camera Tester
ilsonemo's Avatar
This is somthing i quickly made up should help a little more
Old 02-08-2009   #4
Quote Originally Posted by ilsonemo View Post
2. drain the tank
8. remove the tank
hope that helps
Thanks Ilsonemo, you are a star!!!
Old 03-08-2009   #5
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
If thi sis a second hand tank you are going to remove, before removing, check the seam around the tank is not 'crunchie'
You wouldn't want to spend time removing a knackered tank.
Specialist online retailers will help you get a new one.
SPD
Old 03-08-2009   #6
David C has donated!
Yes I wouldn't bother with a s/h tank.
A new one is only about 70
2003 Audi TT 3.2v6 DSG
2012 Renault Twingo 1.2
x1999 Alfa 156 Selespeed
1994 Fiat Cinq 899cc
David C is offline Reply With Quote Quote
Old 03-08-2009   #7
Get a wriggle on!
levemircento's Avatar
levemircento has donated!
yeah much as above, just done this job on mine last week, one of the bolts to a bracket on the rear beam snapped on removal, easy to fix as there is an extra mounting hole in the bracket on the beam
I drained my tank as follows, I removed the fuel feed to the SPI unit, and extended it to reach containers at the front of the car, then I added a 12v feed to the green wire of the fuel pump, this gets the pump pumping and you can fill up your containers/empty the tank until the pump wont pick anything else up
Upon dropping the tank from the car, there may be up 4L left in it
Getting the pump assembly out from the tank was awkward, until I removed the twist off level sender first, found it odd that there were bare electrical connections in the tank/on the pump
Refit tank and use a new fuel filter as theres every chance it will have filled with particles of rust from the tank walls
must be time for a brew
levemircento is offline Reply With Quote Quote
Fuel leak near fuel tank Wee Ed Newbie Central 2 12-08-2008 23:44
(T) How much fuel does your tank take! Binkie 500 14 21-07-2008 23:53
(T) JTD in-tank fuel pump, fuel return? Dax Stilo 2 02-11-2007 16:45
(T) Cinque petrol tank removal Williecleuch Cinquecento / Seicento 5 24-02-2007 10:17
(T) Cinq Fuel Tank\ Fuel Guage arseofbox Cinquecento / Seicento 0 25-09-2003 03:35
