TurboCinqy1250
Member
For a while I have the following problem.
If I drive at higher speeds above 130 km/h at continue speed the boost is just below 1 bar.
At the moment the car doesn't acellerate the ECU stays in closed loop mode. @ lambda 1 14.5 AFR.
Because of this the Exhaust temp rises to 850 to 900 degrees celcius. A bit to high I think.
If I acellerate realy slow the boost falls in but it also runs in closedloop.
Is there a possibility to change the closed loop mode or disable it?
Otherwise It is possible to change the lambda value with my SMT-6 if necessary.
Or are there other options.
best regards Dennis
best regards Dennis
