I have just fitted my 1.2 engine and have a few problems.
for a few months with my 1.1 the engine had a weird and random flat spot. and a week or so before the engine swap the engine had a strange idle where some times with would hop (it would rev up and down a hundred or so rpm every 2 seconds or so) there was no warning light.
now I fitted the 1.2 engine and it was still the same (maybe a little worse) so I disconnected the lambda sensor to see if it would throw up a warning light. Nothing! ran the same.
So I fitted my new chip and now when the engine is started the injector light blinks for about 20seconds then stays on. the car is in limp mode with a 5000rpm rev limmit it seems.
Disconected the lambda again and the light still flashes and stays on with no change to the engine.
anyone have any ideas? (i recon lambda) but why does the warning show with mckcrich chip and not with stock chip?
