FIAT Auto Specialist Team
Old 10-02-2007   #1
Brake Light
Hi there ive had new Front Brakes fitted, Topped up the brake fluid, And checked to make sure front sensor our in place and back brakes our ok, But still my Light is on the dash all the time,
Any one got any ideas what it could be
The car stops on a penny and the hand brakes as far as i can tell is fine, Need this sorted soon as car needs to go for its MOT soon cheers
If it aint broken, Break it so you know how to fix it
cubixgames is offline Reply With Quote Quote
Old 12-02-2007   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: Brake Light
from what you've said i'm assuming the following
1. the light you describe is the low fluid/ worn pad/ handbrake on light (red)
2. the light was remaining on before the brakes were fitted
in that case, i would suggest you firstly check the switch in front of the handbrake lever.
second i would check the sensor in the reservoir
if my assumptions are wrong and the problem is the abs light, or only happened after you had the brakes fitted, let me know as that changes everything.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
(T) warning light coming on when i brake superstylin69 Punto (Mk2/2b) 6 13-04-2006 22:48
(T) Replacing brake light bulb mbarratt2 Stilo 0 08-10-2005 22:58
(T) brava 3rd brake light rov200 Bravo / Brava 0 22-09-2005 18:49
(T) Hand brake light on Knockout Tipo (Classic) 6 18-04-2005 23:11
(T) 3 Brake Lines & a ABS Light Q TOY Bravo / Brava 1 13-03-2004 02:43
