Technical  Air bag light
Mrmitcham
Hi everyone basicly I've got a 1.6 turbo diesel 2008 bravo one day the air bag lights came on I've put a machine on it and it's not finding any error codes I don't know what to do as I love the car but unsure on what to do with out it costing an arm and a leg
Dean
Dean
Welcome to Fiat Forum. I've moved your post to the Bravo section.
I assume the "machine" is a generic code reader? If so it probably won't pick up airbag faults. You need Fiat specific diagnostics. One good choice is Multiecuscan www.multiecuscan.net and an ELM327 interface with adaptor leads e.g. www.ebay.co.uk/itm/NEW-Fiat-Alfa-ELM-OBD2-Green-Red-Yellow-cables-adapters-Diagnostics-Multiecuscan/282526378637. These need a laptop (Windows XP or later, nothing special). While costing around £6-£70 it's still cheaper than a diagnostic read from a dealer.
This will tell you what is wrong. probably a bad connection. Some Fiats have a problem with the passenger airbag isolation switch that needs a wiring repair.
Robert G8RPI.
