Thread Tools
Old 18-03-2004   #1
Cambelt tensioner, how to check?
A simple question:
How do I know if the tensioner is ok? I just had the cambelt changed for a reasonable price 80 for my Bravo 1.4sx -97. The guys at garage told they didnt change the tensioner, as it looked ok. How can I be sure? Sorry, Im not very good with mechanics...!
Thanks again.
Jan
Jan is offline Reply With Quote Quote
Old 18-03-2004   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
i think you really would have to take the belt of to check for play which is a bit late now,with the belt on i dont think you could really check,of course i could be wrong
The Fiat Cinquecento
Fun While It Runs
Old 20-03-2004   #3
If its black, thats bad news as thats an old version tensioner, if its white it should be o.k but it should be changed at each cambelt.
FiatExpert is offline Reply With Quote Quote
Old 20-03-2004   #4
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
Steven is offline Reply With Quote Quote
Old 27-04-2004   #5
As a rule of thumb I would replace the tensioner and guide bearings at the time of belt change. Don't forget they too have done the same mileage as the belt. The white plastic tensioners found on the 1.8, 2.0 are renouned for failing after changing belt only. The black tensioner on the 1.6 is slightly more forgiving but I would not risk it. Seen far too many fail unexpectedly. Cinq and Seicento belts will rarely make the 63k without braking!
D.White Motors is offline Reply With Quote Quote
Old 28-04-2004   #6
polecat has donated!
Hi Jan,
I would recommend you change the tensioner as soon as you can. It's a stressed plastic component thats over six years old now. Check FiatExperts post for how urgently you need to do it. If the garage still say it's ok, ask them if they'll add the tensioner onto the cambelt warranty.
polecat is offline Reply With Quote Quote
Old 28-04-2004   #7
Italy
A mate of mine showed me a good trick. I had what i thought was a noisy cam belt on my '98 HGT, he said it could also be the tesioner and put a large screwdriver on the central spindle of the tensioner while it was running to see if it gave off any vibrations. It was quite obvious when he did this that it was the tensioner on its way out.
googlethorpe is offline Reply With Quote Quote
Old 30-04-2004   #8
change the tensioner as soon as you can i got it from a fiat mechanic they must be changed with the belt specially if its the original one and that as a fiat dealer any brava/bravo they took in as a trade in replaced orignal belt and pully regardless of milage
but "fiat say there is no fault"
mteck is offline Reply With Quote Quote
Thread Tools
(T) Cambelt Question JamesO Bravo / Brava 12 07-10-2005 20:54
(T) Cambelt change puckapunto Punto (Mk2/2b) 6 03-11-2004 21:47
(T) Punto breakdown - cambelt? nbandal Punto (Mk1) 3 19-07-2004 20:29
(T) Cambelt Sam96 Marea 8 05-12-2003 01:19
(T) Punto 75 SX '98 battery & electronic check problem zokipet Punto (Mk1) 3 22-02-2003 04:37
