im Axle Specialists
Old 16-06-2006   #1
Italy
Brake Warning light
Firstly, I'm guessing thats what the warning light that came up on the dash was. It was the same as the hand break light without the ! in the middle.
Was driving for the best part of 2 hours solid yesterday, which was quite hot anyway. only rest my car had was for 5 mins when i picked my mate up. I took a wrong turning & ended up at a housing estate with an unsued car park. Turned the car around and ran over someone's front bumper. Don't know how I didnt see it, was hardly moving & was about to miss the England match!
Anyway, both offside tyres ran over the bumper and once I got moving, the light came on and started flickering (not flashing). Sometimes it would stay solid, other times this light would go out and only come on when I pressed the foot break. After the match, all was fine; although i havent driven the car for a similar amount of time in such heat since. There was no (noticable) change when i press the foot break. Any ideas what may have happened?
The Yellow HGT 155 breathes again...
Johnny Bravo has returned!
G Spag is offline Reply With Quote Quote
Old 16-06-2006   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Re: Brake Warning light
perhaps you caught the low pad indicator wire and its earthing out intermittently?
Old 16-06-2006   #3
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
i guess you checked the brake fluid reservoir? it may be low due to a leaking clutch slave cylinder or a leak in the braking system. better check to be sure just in case you damaged something and caused a leak.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
(T) Dodgy Brake light.... onfire_82 Stilo 6 27-06-2005 18:34
(T) Brake light staying on when lights on Shakey Cinquecento / Seicento 2 22-09-2004 10:50
(T) Brake Pad Warning Light cscotson Bravo / Brava 0 14-09-2004 11:25
(T) Brake bulb warning light anthemmaster Bravo / Brava 10 24-03-2004 03:44
