mattk
Hello,
A little while ago while driving along in my Bravo HGT I heard a slight 'crumbling' noise followed by the engine cutting out. After this, the engine refused to restart. On getting the car back home it was quite easy to see the origin of the problem.
The metal tensioner pulley of the first auxiliary belt (connected between crank shaft and what looks like some hydraulics for steering and/or brakes?) had failed, and had seized up twisted at an angle. The belt itself had slipped off this pulley and was jammed against it and the engine block.
I cut the belt off and that freed the engine, and I was about to go out and get the replacement parts when I thought I should probably check that everything else was okay.
Here is my question: is there any reason why the engine shouldn't start with this belt removed? Because it doesn't. All I get is a dry sound as the engine is turned over, as if there was no fuel/spark. Does the alternator need to be working to simply start the engine? Or is there some other reason?
(Everything else appears to be okay, fuses, etc., and the timing belt seems undamaged.)
Cheers,
Matt.
Cheers,
Matt.
