Yuvalgerson
- Mar 19, 2009
- 13
- 6
Hello to all
I had a for a long time a/c problems in my Marea. Leakages in condenser, hoses and expansion valve, hade to take the dashboard and vent unit apart (took me two days work)
Now no leakage, I hope the last problem is the compressor stops for no reason, I have tested the system with my gauges, cleaned /replaced filter drier, vacuumed it and recharged it. The pressures are o.k., I tried to replace the three stage switch, didn't help.
The compressor is a bit noisy but he build up good pressure, thinking I have a problem with is the thermal contact in the compressor or the inner regulator of the compressor isn't working.
Any one is an expert in a/c systems.
