Old 15-09-2008   #1
bravotony has donated!
Pencak Silat 2 Champion, Rubber Bandit Champion, Smashtastic Cricket : World Cup Hero Champion
locking wheel nut problem
as i need to replace my wheels the pins on my nut for my locking wheel bolts have snapped so now i stuck was just wondering if anyone can advise on how to get the locking bolts out
thanks
bravotony is offline Reply With Quote Quote
Old 15-09-2008   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: locking wheel nut problem
its usually easy, but the method depends on the type of locking nut you have.
usually you can hammer a 17mm or 19mm socket on. alternatively you may need to use some long nose pliers. some types (e.g. mcgard) are difficult to remove and you need to have a few lengths of steel rod inserted in the grooves and then use something (long screwdriver) to turn them all.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 15-09-2008   #3
cheers jug its got 3 pin holes not sure what make they are
Old 15-09-2008   #4
jug
jug's Avatar
Trader Rating: 1
jug has donated!
ah yes the 3 pin nuts. they almost always have the male pins on the key and the female pins (or holes) on the bolt. you can insert a pair of long nose pliers into 2 of the 3 holes. lever the pliers round using a screwdriver between the 2 handles. that is usually enough to get the locking bolt off. be careful not to slip and scratch the alloy.
Old 15-09-2008   #5
cheers jug dont matter bout slloy as i getting four new ones as cannot find a matching one to my set
Old 16-09-2008   #6
hi jug tried the pliers method doesn't seem to get enough leverage, then tried a 17 mm socket over it and it just span
any other ideas maybe a 16mm ???
please help lol
Old 16-09-2008   #7
Speedbump grimacer
Adrian Bravo's Avatar
Trader Rating: 1
Adrian Bravo has donated!
If you have a welder jsut weld a nut or something like a old socket set to it?
Adrian Bravo is offline Reply With Quote Quote
Old 16-09-2008   #8
jug
jug's Avatar
Trader Rating: 1
jug has donated!
Quote Originally Posted by bravotony View Post
yes. if 17mm spins then try a 16mm socket.
alternatively they may have a sliding collar to stop you hammering a socket on, and that is why the 17mm socket could spin without loosening the nut. if that is the case then you need to use the plier method or contact the manufacturer for a replacement locking key.
Old 16-09-2008   #9
yeah i thinjk it is a sliding collar but this is how the garage got the other one off, is there a way to break the collar off leaving just the main bolt head or would it just be worth letting a garage sort it ????
Old 17-09-2008   #10
jug
jug's Avatar
Trader Rating: 1
jug has donated!
in the past i have used some water pump pliers to nip the sliding collar, preventing it from spinning. this method depends on enough of the nut sticking out so you can grip it. been able to do it depends on the wheels. failing that i hammer the socket right on as far as possible to kink the collar, preventing it from turning. this leaves you with the problem of getting the socket back off once you remove the nut.
Old 25-05-2011   #11
Daily Drive 5dr 1.8 Focus
MickeyBravo's Avatar
MickeyBravo has donated!
sorry to dig and old post up but this sounds like the exact same locking key as i have..and the same problem lol
A Fiat Marea in a Bravo shell...its good to be different
Now with working Steering Wheel Controls
FC Performance Chip.
Currently sorned
MickeyBravo is offline Reply With Quote Quote
Old 25-05-2011   #12
Here to help
bridges's Avatar
bridges has donated!
here is a little tip.
Tighten up by a tad the other 3 wheel bolts. This pulls the wheel in tighter by a teeny tiny bit and releases the pressure between the locking bolt and alloy.
At this point you can give it a tap with a punch or tap over a tight socket etc.
Likes MickeyBravo liked this post
Ink Black Coupe,
Koni susp' kit, Strut/Subframe bars. Camber bolts, 3g Discs, Yellow pads. Ram air, S.I.P, FMIC, Superspool turbo, Aquamist, Full S/S decat exhaust. Hid's, Le kit and Tan leather.
Alfa 156 16v Jtd-m Ti 150bhp
http://i54.photobucket.com/albums/g1...2006/alfa1.jpg
bridges is offline Reply With Quote Quote
Old 26-05-2011   #13
thanks mate,gonna have to try a tight socket then and by reading the above ill also try long nose pliers as i havnt got a punch.
Mike
Currently sorned
Old 26-05-2011   #14
You could just buy the propper tool.
http://www.tooled-up.com/Product.asp...ferrer=froogle
jimmyybob is offline Reply With Quote Quote
Old 26-05-2011   #15
yer ive seen them,but havnt got an impact driver so would be pointless.
Currently sorned
(G) Locking wheel nut :( crazydave Punto (Mk2/2b) 4 12-05-2008 18:57
(G) TSW Alloy Wheel Locking wheel nut Tool Missing PUNTOELXBERTONE Punto (Mk2/2b) 2 02-05-2008 08:25
(G) Locking Wheel Nut Lawrence_16 Stilo 5 22-11-2007 01:47
(G) lost locking wheel nut furby Cinquecento / Seicento 2 18-01-2005 10:36
Wheel Locking Nut Help!! Bushboy Leisure Lounge 3 21-11-2003 04:15
