Hi all,
I recently came back from a trip in Italy where I bought a very nice red Fiat 500L and imported it by sea freight. This is my first car and the first forum post here. The forum helped me a lot before purchasing the car so many thanks!
A bit of background story on the vehicle:
- I bought the car from a guy who seems to be passionate with cars and takes good care of the ones he owns.
- The car was checked at around 0 degrees C and now it is at an average ambient temp. of 30deg C.
- The car seemed to be running very smoothly and electrics&mechanics systems seemed to be in very good shape when checked in Italy.
- The car was shipped by sea and sat unused for about 3 months total.
Now for the tricky part
When the car first arrived, I had to drive it home for around 50km. First start (after battery sat for about 2.5 months) was smooth. After driving at ~80kmh for 15min the engine started running rough. Felt like something gave little pushes to the car from the rear every 10 sec or so. Not long after, it came to a halt at the side of the road.
Trying to start it (engine hot) didn't work. Jumper cables didn't help. After about 20mins, the car started again. This happened 3 times during the 50km trip where the third time the car didn't start for about 1.5 hours (Each time trying with jumper cables, different combinations of 'choke' and throttle).
The strange thing was that the starter seemed to be running very slowly and a lot of times stalling and not even cranking the motor (This is why we used jumper cables to another car, it felt like the battery had no juice...).
Turns out the battery is good (also checked the car with a new battery since) and the problem now appears whenever I try to start the car
Push starting the car seems to work great but I havn't tried to drive it more than 5 mins so I don't know if it will run smoothly for long.
Had the carburetor cleaned (especially the idle jet as mentioned in one of this forum posts), replaced the earth cable connected from the engine to the chassis.
A bit more details that may solve the problem - It appears that there is still a 'bad earth' problem because the direction blinkers don't work very well and light up the brake light each time they turn on/off. Sometimes they even not working or fade out after two blinks or so.
I thought it might be an overheated fuel pump but the problem happens on cold starts as well (Fuel pump is pumping fuel - checked)
Would appreciate any help an/or advice!
