Any thoughts on what has caused this sort of damage to the piston skirts? There appears to have been friction with the cylinder .
What is peculair about the marks on the above pistons is that they don't extend down to bottom of the piston skirts. The piston's diameter is at it's largest on the piston skirt right down to the bottom.
'Jackwhoo' did ask if the marks were on both sides of the pistons but I don't think Toshi975 answered this? Also, he didn't say if there was any damage to the cylinder bores?
If both sides of the pistons have similar damage then I'd suggest insufficient piston to cylinder clearance. There will tend to be more severe damage on the thrust side of the pistons...
As was said (again, I think by 'Jackwhoo') the piston to cylinder clearance might be fine with the engine cooled down but be used up as the engine heats up. The clearance recommended is to allow for piston expansion as the engine heats up. It includes a margin to allow for an engine running hotter than normal e.g. hot climate, labouring up a hill, full loaded, poor quality fuel? etc. It also has to leave sufficient clearance for an oil film to exist under all these conditions. If the engine gets very hot and piston to bore clearance were to be reduced to absolutely zero, then oil cannot get between the piston skirt and the cyl. bore.
I'm wondering if this engine was running exceptionally hot? Various factors can affect engine temperature on air-cooled engines - incorrect fan, slipping fan belt, thermostat not opening, cylinder fins covered in dirt etc. incorrect ignition timing, especially too far retarded! (some other air cooled engine have oil coolers e.g. VW, Citroen 2CV, the fins on these need to be kept clean). Increasing the engine capacity may surpass the cooling ability of the standard system, fan, fan drive speed etc.
Toshi975 may actually have already found the cause of the problem with his mention of oil sprays holes in the con rods being accidentally blocked-off. Some con rods have no holes.
Some have one hole spraying to one side - this is usually to lubricate camshaft lobes and perhaps a little of the spray does hit the cylinder bore (you don't want too much being sprayed onto the cylinder wall as it can overwhelm the oil control rings on the pistons).
Some have 2 holes, one for the above reason, the other to cool the underside of the piston crown and lube the small end bearing.
Remember also that there is oil being sprayed out each side of the big end bearings and the crank is rotating quickly so the oil get sprayed everywhere anyway.
(Anyone who has ever pressurized the main oil gallery of an engine at rest with the oil sump removed in order to check for a faulty/worn crank bearing will know what I mean!!).
So, How to fix the problem? I think these pistons might be re-useable. There doesn't seem to be any damage at the ring lands or at the bottom of the piston skirts. I'd measure them and check against their original dimensions to check that the skirts haven't collapsed.Then clean up the torn surfaces. Check the cylinder bores for roundness everywhere. Note that larger cylinders especially if standard cylinders are significantly over-bored can distort in strange ways in use. You might need to increase the piston to cylinder clearance a bit more than you already have by honing the cylinders. Depending on what I found, I'd either hone to the max clearance specified by Fiat or go a little larger due to the larger pistons now being used.
(In the old days, piston and ring clearances used to be given in terms of thousandths of an inch per inch of bore size, there were different figures for air vs water-cooled engines. It was normal practice to increase the clearances beyond this on modified/race engines.)
AL.
