It is acceptable to wait a week for a windscreen chip repair
no. competition is high ring another (independent) repairer
Temperature changes is unlikely to do anything to it this time a year, so I'd rule that out - however a bump in the road could still do damage, so I'd get it fixed asap
Or at least cover it with one of those fancy stickers, to stop dirt getting in
Bloody think cracked on the way home from work this evening
Oh well, thats £75 to hit the wallet. Is it a danger to leave it? The car isn't due an MOT for 18 months and its not in field of view :devil:
ring an independent often they can lose most if not all of your excess
a lot of the roof strength is in the screen
I'll get it changed then. TBH I'll probably put it though the insurance, I'm going to have fun I think as the OEM Toyota screen has a special rain-x like coating, but doubt their normal pattern parts do, and apparently getting them to install it properly so you don't get ghosting on the Head Up Display can be a ball ache also
I have a friend who is a local (to Norwich) automotive glass specialist, you could always give him a ring, (total windscreen solutions 07747891300) he does a lot of super cars and motor sports cars as well as all the usual stuff, so should be able to help and advise on oem screen v patent parts costs and insurance
Ok heres a question, wife gets her nails done which is then cured under UV light,
Nail polish is basically car paint, so that being could you paint a car then cure it in a UV booth . .?
Why does the Climate control automatically select recirculated air when it's warm out? I'm pretty sure it's warmer in the car than outside until it's been on for a few minutes. I can sort of see the logic of it scavenging air it has already chilled but does it from the moment you turn the key. In normal conditions it always runs fresh air from cold start, although it's been so warm eco mode has deactivated and knocked 2mpg off my economy.
It's more economical, as once cool if the internal cabin temp selected is lower than externally it'll be working less hard to keep cold air cool than it will be to cool warmer external air.
In the Prius it only recirculates as you've mentioned when in Eco mode as it used less draw from the battery, due to the reasons explained above.
should i go see new minions film, i already cant looked at a banana with out a little minion voice in my head saying ooh bahnanah
Does anyone know anything about pressed plates?
