I am very desperate!!
My Fiat UNO (with fuel injection!!!)
Type: UNO 146 1000/1300 T
Trade name: UNO 1,0 S 3T
Test date: 28.03.1989
always dies, as soon as I go from higher rpm into the idle speed!
But when the engine is in idle speed it works fine!
The car already was several times in a garage, because of this problem!
This effect is worst, if the engine is still cold.
I think that the Choke does not work correctly!
In the garage the idle speed controller and any distributor were already exchanged!
But the problem remained further!!
I am not a mechanic, so I cannot say you exactly which parts were exchanged!!
I have already changed the idle speed screw a little bit! But the engine still dies,
if I go from higher rpm into idle speed!
What could be the problem?? It would like to know gladly exactly,
so that I can make exact instructions in garage!
Because up to now the car was in a Fiat-Garage to eliminate the
problem and a private mechanic also did not find this problem!
I would be grateful for a rapid answer!
