Hi all,
Uno 45 MK1 1986 with 999engine.
Changed the heater matrix to new one 2 weeks ago.
All worked fine until 2 days ago when I noticed the temp is 1 line above half after 20 min drive.
Head was rebuild 1 year ago, I changed everything, radiator, thermostat and new water pump since then.
After changing the heater matrix, I bleed all the system, opened the bleeding caps and filled the system until no bubbles.
All the hoses are hot at the same way when the car is running.
The weird thing is, when the car reaches to half temp, fan starts at exactly half and car is not overheating. the overheating occurs only after 25-30min driving.
I changed today both coolant and fan switch sensors but it's the same.
Fan looks to be working ok, goes on and off every 1-2 min or so.
NOTE
Coolant is not boiling.
NOTE
