Pictures as promised!
Damage from the outside. You hardly notice it thankfully unless you know where to look!
Damage from the inside:
I spent ages trying to leave the RHS headlight in place and only remove the indicator, but after giving up, I found out why I wasn't able to slide it off easily!
Someone had broken the slats that the indicator sliders fit into, and so it had to be screwed in place to stop it from falling off when taking a sharp left hand corner!
Here you can see the hole that was made.
This is the damage that was done to the tyre (well, not he only damage done, it is like that the whole way round it) - this tyre is now on the rear right hand corner.
This is the front left wheel arch after the wheel had been rubbed on it repeatedly. The damage from the tyre came from the sharp looking bottom corner digging into the wheel
SEXY NEW WISHBONE! (and sexy 2nd hand driveshaft á la LouieBee)
I decided to get the car up on axle stand so I could have a good look underneath the engine, and see if I could work out what the rubbing noise on the front left hand side was (note - this is NOT the bupbupbupbupbup noise I reported - it is a grinding noise that has been there since I changed the wheels over from their stick thin original steelies to the sexy alloys)
This is what I believe the culprit to be. At full lock, the end point of the steering rack touches the innermost rim of the wheel, causing a horrible grinding and scraping noise. That small round circle near slightly above the middle of the picture is the bit that it rubs on. I remember a thread a while back after I had posted about this saying that it was the wheel rubbing on the bottom of the gearbox. I can categorically say that this is NOT the case at all. It is the steering rack end arm that causes it!
This is a better view of the part in question:
However, I also think that the problem could be made worse by the fact that the tyre rubs on the wishbone at full lock too:
As you can see, it is jammed up tight.
That all got sorted. I did however manage to totally bugger up my car jack
I was unwinding it (after finishing all the work!) slightly too vigorously and rocked the car off the jack. Thankfully I was nowhere near it, and it just dropped onto the wheels only. Not really that fussed either! I have the spare jack from my old transit van anyway so just chucked the broken one away.
Clear indicator. Not much more to say really
Both sides done.
That's about it really!
