Cooling: Water evaporating from radiator cap - tight & in perfect condition, hoses secure and in satisfactory condition ; no trace of leaks elsewhere, temperature shoots up to boiling point...
Ignition timing: Removed distributor (Magnetti Marelli) completely, corrected loose plug connection on ECU/Modulator - factory fitted directly on distributor - replaced and adjusted timing according to Haynes Service Manual - No problems there
Starting: Starter motor seems to "stuck" on turning the ignition key (No noises & battery in good shape)
Any suggestions ?....
