FIAT Auto Specialist Team
Old 29-03-2009   #1
removing old barrel from barrel housing
I want to remove my old ignation barrel and I can not remove it if you can help please tell me thank you
sachinib
sachinib is offline Reply With Quote Quote
Old 29-03-2009   #2
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: removing old barrel from barrel housing
Hi, Welcome to the FF.
I can't remember specifically for an Uno, but for most Fiat steering/ignition lock barrels you need to have the key in the barrel and turned to the first position, then push a small screwdriver into the hole or gap in the side of the barrel housing. You can then pull the barrel out using the key.
There's a spring loaded catch that holds the barrel in but you can only press it when the key is in the lock and turned.
Dave.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
(T) Removing ECU and ignition barrel TECKNO Bravo / Brava 3 23-02-2008 23:03
(G) New Barrel sammie Punto (Mk2/2b) 3 03-06-2007 17:13
(G) Removing the ignition Barrel Tweedbean Cinquecento / Seicento 29 28-04-2007 21:34
Removing Fuel Cap Lock Barrel Saino! Security 2 15-06-2006 12:21
(T) Removing the lock barrel mattyj10 Punto (Mk2/2b) 6 04-10-2005 00:05
