Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->removing interiour quarter pannel trims<!-- google_ad_section_end -->
Published by chris3234
27-04-2020
Difficulty Level: 1
User Rated:Unrated
you will need a selection of torx bits for this
start by folding the rear seats down then remove the covers from the rear seat back mounts
https://www.fiatforum.com/attachment...1&d=1587991622
next remove the two lug holding to boot carpet in place they should screw out
then you can remove the two bolts holding the rear seat bases in place
after removing the screws lift the front of the base up then pull it forward out the way and rest against the front seats
pull the door seal out the way then you can get your hand behind the trim and see the push pin type fixings if you have trim removal tools you can try and get them behind to aid removal by popping the fixings out the bodywork
just work gentally one at a time and you should be able to pull the pannel away and forward enough to get the upper gray pannal away
https://www.fiatforum.com/attachment...1&d=1587992063
next to remove the gray pannel you will need to poput the cover for the fixing bolt under the (airbag) word dont worry there no actualy airbag here
after the bolts is removed it just plastic fixing against that come away with a tug
https://www.fiatforum.com/attachment...1&d=1587992448
finally to get to the pannel holding the boot light and power socket theres 4 two part fixings
to remove these pull the centre out then get nehind and pull the whole fixing out of the part
https://www.fiatforum.com/attachment...1&d=1587992625
after the 4 fixings are remove its just trim clips again that need a pull to remove
and viola your done and have access to the rear seat belt mechanism and wiring leading to the boot hatch also if like me the rear washer tube that i had to repair
https://www.fiatforum.com/attachment...1&d=1587992769
Comment
Search this Guide:
(G) Removing Fog light trims Ziggy122 Punto (Mk2/2b) 6 17-12-2012 20:58
removing side trims mk2 and smoothing off BTG Lets Talk FIAT 2 07-09-2010 19:46
(S) removing side trims mk2 and smoothing off BTG Punto (Mk2/2b) 1 29-08-2010 23:44
(T) Removing Wheel Trims/Rust steveo4245 Palio 2 17-07-2006 12:33
