you will need a selection of torx bits for this
start by folding the rear seats down then remove the covers from the rear seat back mounts
next remove the two lug holding to boot carpet in place they should screw out
then you can remove the two bolts holding the rear seat bases in place
after removing the screws lift the front of the base up then pull it forward out the way and rest against the front seats
pull the door seal out the way then you can get your hand behind the trim and see the push pin type fixings if you have trim removal tools you can try and get them behind to aid removal by popping the fixings out the bodywork
just work gentally one at a time and you should be able to pull the panel away and forward enough to get the upper gray panel away
next to remove the gray pannel you will need to poput the cover for the fixing bolt under the (airbag) word dont worry there no actually airbag here
after the bolts is removed it just plastic fixing against that come away with a tug
finally to get to the pannel holding the boot light and power socket theres 4 two part fixings
to remove these pull the centre out then get nehind and pull the whole fixing out of the part
after the 4 fixings are remove its just trim clips again that need a pull to remove
and viola your done and have access to the rear seat belt mechanism and wiring leading to the boot hatch also if like me the rear washer tube that i had to repair
