General zolja012
General zolja012
zolja012
I need wire connection for Fiat Ducato 2.3 JTD
More information?
Wiring for which part? Location of components or wiring diagram?
The Fiat circuitry is quite involved and cannot be shown in one single diagram.
Peter :idea:
I need something about fuel injection.
My problem is: fuel does not come to the injectors.
G'day Zolja012
The 2002 CD I have shows the attached circuit (click the preview for larger version) and says the following:
"2300JTD
Engine management control unit M10 controls and governs the entire electronic ignition and injection system.
Engine bay control unit B001 houses fuses F02, F11, F17, F18, F20, F21, F22, and relays T19, T09, T10, designed to protect and control the supply to engine management unit M010 and the various sensors and solenoids.
Main injection relay T09 controls the entire system: t is excited by an earth signal from pin 13 of connector A of engine control unit M010 and then forwards a power supply:
to pin 4 of the control unit via the line of fuse F17 of B001;
to pin 5 of the control unit via the line of fuse F22 of B001;
to sensors: L062, L030, K041;
to glow plug preheating control unit M015.
Fuel pump relay T10 of B001 is supplied by the line of fuse F21.
This is excited by a control signal (earth) from pin 24 of control unit M10 and supplies power to fuel pump N040.
Pins 1, 2 and 3 of M10 are earthed.
Diesel preheating relay T19 is supplied by the line protected by fuse F20.
This is excited by a control signal (earth) from pin 110 connector B of control unit M10 and supplies power to diesel heater coil O020.
Control unit M015, which manages the heating of glow plugs A040, is supplied directly from the battery via a line protected by the fuse, exchanges control and management with pins 22 and 62 di M010, which controls the timing. Connector C of control unit M015 - pins 1, 2, 3, 4 - is connected to glow plugs A040A, A040B, A040C, A040D.
Control unit M010 receives signals from the various sensors in order to control all engine service parameters.
Engine temperature sensor K036 communicates with engine management unit M010 at pins 82 and 83 of connector B.
Air flow meter K041 receives a general power supply from fuse F11 of B001. It receives a reference voltage from pin 88 of M010. This is supplied by the control unit from pin 97 of M010 and sends a signal proportional to the air flow to pin 89. An air temperature sensor, also housed in K041, sends an air temperature signal to pin 86 of M010.
Accelerator pedal K055 contains two integral potentiometers (a main one and a safety one).
The former receives power and an earth signal from pins 78 and 76 of M010 respectively and sends a corresponding signal to pin 77. The latter receives power and an earth signalfrom pins 81 and 79 respectively and sends a signal to pin 80.
EGR solenoid L030 controls exhaust gas recirculation. It is supplied by a line protected by fuse F11 and is controlled by a signal from pin 16 connector A of M010.
The solenoid on throttle body L062 reduces and closes the throttle opening, e.g. when the engine is turned off. It is supplied by a line protected by fuse F11 and is controlled by a signal from pin 15 connector A of M010.
Injectors N070 receive a power supply to enable opening from pins 117 (cylinders 1 and 2) and 118 (cylinders 3 and 4) of M010.
The engine management unit sends a command to injectors N070 from 119, 120, 121 and 114 for cylinders 1, 2, 3 and 4 respectively.
Engine management unit M010 is equipped with a CAN connection - from pins 9 and 10 connector A - to ABS control unit M050 - pins 29 and 30 -.
Engine management unit M010 governs activation of the warning lights on instrument panel E050 from pins 21 and 14 of connector A if the injection system malfunctions."
Peter
