It has been stated on here a number of times the 123 electronic distributor, in particular, needs to be set up using a strobe-light.
Equally frequently there are other contributors pointing out that some freehand adjustment can make the engine run more perfectly.
Prior to some engine shunting I plan to do I have just re-instated the conventional distributor. I found that a tweak of retardation on the static timing made the car run better. Overall it really does run better with points. I suspect that the springs may be worn giving a more sporty advance curve
The 123 is obviously very precise but the analogue nature of the points gives a nicer driving experience for me.
Next time the 123 is fitted I will be inclined to experiment with its static setting or to trial a couple of its alternative curves.
The whole experience tells me that in my case there is a relatively wide range of static timing settings that work, but that the best one isn't necessarily the precise factory setting.
I suppose that makes sense as not all fuel is the same, all engines will have different wear characteristics etc. etc.
so what are your experiences and would buying a timing light make me even more confused/dubious?:spin:
