Hey!
I happily received my Fiat 500L from Italy today and a problem immediately occurred with starting the car. I can insert the key to the ignition switch on the dashboard but can not turn the key in the switch. It looks like the switch is stuck/jammed. What I have tried already:
1) tried every key multiple times
2) lubricated the ignition switch
The ignition switch has three wires at the back and the car does not have a steering lock (what is commonly problem with modern cars if you can't turn the key).
Has anyone had similar problem and how did you solve it? As much as I have searched from the forum or google, I haven't found anyone with similar problem. Also, has anyone disassembled the ignition switch? I found some posts, but the switches in these seem a little different (with more wires at the back) and they do not have disassembled the lock mechanism itself.
Best regards
Kev
Best regards
Kev
- Model
- 500L
- Year
- 1970
