Just a guess, but maybe a broken wire in the loom at the door hinge area.Hi i have a 2006 1.4 punto, only issue i have is when i open the door, it brings up a yellow triangle and yellow pad light with the red door light. Has anyone else had this issue and how did they fix it? Cheers
Hi seems to be all doors. When doors are closed no lights, but when any 1 door is open, then the 3 lights come on. Im a newbie with cars anyway but this has me miffed. The 2 lights are a faint yellow thoHi
The Yellow Pad has me confused..
I have only had Diesel Grande's.. but dont recognise that
Quick test.. just the drivers door doing this..??
Open drivers window... close door... is light off?? ( you can lean in to see screen better )
Walk around.. open passenger front door
Leave open
Walk back to drivers side..lean in ( with drivers door still shut)
is PadSymbol On..or Off..??
You now know wether its only triggerrd by drivers door![]()
Can you add a picture..??
Worth a Thousand Words![]()
Yeah the edmissons light is a light brighter when first comes on. These two are very faint. Looks brighter in pic but are faint. Manual. Its strange as only comes on when doors are open. Had pads done couple weeks ago. Just wondering if the drivers door loom can cause this if theres a break in wire? Would it also affect other doors too? Thank you for advice so farThe triangle and circular arrow is unknown to me..
Is your car a manual..or automatic?
Doesnt have 'Stop-Start' does it?
Ok thank you. Mot aint due till aug but just wana sort that issue as its an alright lil car. Thank you for adviceDash otems Glowing strangely could be a whole range of things
My 2012 has a similar thing..but seatbelt lights.. supposedly caused by Damp in the PCB of the dash..
Ive seen it for the last 5 winters.. no other problems
BUT...
Grande door wiring can get stressed and break..
My old 2007 had ElectricWindow problems.. Really weird.. but wiring repairs fixed it
I will add a link![]()
Thank you for that, will be taking a look sunday as only day off ive got but ill get back to ya if i sort it or dont. Cheers![]()
Drivers Window Stuck OPen | FIAT Grande Punto
HI All, First post on here. I have been a long-term lurker after buying my GP about 4 years ago (06 Plate Eleganza). Many forum members have helped me over all the little issues these cars have! Anyway, I have now come up against a problem I haven't seen elsewhere, so I thought I'd register and...www.fiatforum.com
My wiring is at the bottom..this damage isnt unusual
Peel back the rubber boot and look for wires that have lost their insulation..
That might explain your issues
I unplugged my loom..as I needed to Solder some repairs
The Grey plug
Has a mechanism in it..
The looped handle on it drives Gears inside the plug
So jiggle the plug as you slowly move the hoop..and it will drive the plug out of the socket
(Reassemnly can be fiddly.. timing the gear so the plug and hoop are down home together)
ONLY UNPLUG IF NECESSARY !
You should be able to view the wiring with the plug still in the door pillar![]()
