- Joined
- Sep 29, 2013
- Messages
- 476
- Points
- 180
I've ordered all the parts and got dash stripped right out. Am I right in thinking I can cut the 4 wires at the D018 connector and fit them into a new 4 way along with the 4 wires from the stalk.
Something like this.
https://www.ebay.co.uk/itm/Quality-2...cAAOSwanRXhhZj
That would work fine. as long as the quality of fit on the male and female pins is accurate, then almost any connector is OK. I used ex-PC stuff as I had it knocking around. You can cut the 4 wires as they go into the black plug; this is what I did. I made short extensions to these wires to give more room for soldering and manipulation as the harness is short on slack. I think, judging by Burstner685's recent install, that it is the POSITION of the 4 wires in the black plug rather than their actual colours, that determines which of the 4 connects to which of the 4 from the stalk, as he had colours different to mine and it still worked. However, temporary connection there might be an idea to see if it all works as expected, then make permanent.The trick is remembering which colours you are using to connect things, take plenty of unambiguos fotos and make notes!
