wot do i need to istall my sub and how do i do it
monkey dust
eyemouth
i have just bought a fli active subowoofer and was wonderin do i need to get an amp and wirring kit before i can even think of installing it i need help with this as i bought this from ebay and it came with no instructions that f**ked me a bit so any help would much appreciated
bozzy
Veracocha
Birmingham, United Kingdo
If it's active it should have it's own amp built in. You need to run some power and RCA cables to the boot if that's where your sub is going.
OP
OP
M
monkey dust
eyemouth
thanks for the help wot are the rca cables would i just run them from the battery do i need a wiring kit
bozzy
Veracocha
RCA cales take the signal from your head unit to the Amp/sub. You will also need power from the battery through to the amp. You can buy a cheap power cable set-up and run it through your bulk-head, under your carpets or your sills through to the rear.
sam n leigh
you would need to buy a complete wireing kit you can get 1 from halfords for £20 you would need to run an earth wire from your amp and a posative from your battry to your amp you would then need to run an remote wire and phono leads from your hedunit to your amp then run your subs off your amp
jug
blessed are the apostates
Durham
the active sub needs the following connectoed to it
RCA cable (it has 2 plugs at each end) --- connected to the back of the headunit, use the 'SUB' connectors
remote cable (thin blue) --- connected to the blue remote wire on the headunit harness
live cable (thick red wire) --- connectoed to the battery positive terminal, use a fuse on it
earth cable (thick black wire) --- connectoed to a good earth on the car body
how you route all these wires is up to you. getting the live from the battery to inside the car is usually the most difficult bit.
