Technical wont start first or second time but will on third go
FPGT3
Would appreciate any suggestions really my 97 gt wont start first time it just seems like theres not enough power in the battery but thats been checked and its fine. Turns over but doesnt catch. Second time it starts but nearly straight away it then cuts out. Third and final time it starts and revs up on its own but sometimes it tries to cut out when i touch the accelerator but doesnt. It revs itself up to about 2,000rpms and then it goes ok. Once im off my driveway it runs perfect. The car runs perfect both cold and warm its just the starting problem. Its starts fine when turned off and still warm though.Has had a new crank sensor, air flow meter, lambda sensor I have also wire brushed the spark plugs and cleaned the throttle body. Any ideas ?
whats your problem ? dick head
wow, how very mature....
my problem is duplicate threads, makes it hard for people who are trying to help actually help you...i would have been one of thos people but dont think ill bother now.
Yeah ok thats fair enough It just sounded like you were being funny. I do appologise. The car is fine now anyway.
:yeahthat: when your trawling through the forum opening thread's trying to help, it dosen't make things easier having 3 in different tabs/windows by the same person asking the same thing.
A little tip, if no-one has replied and you want to re-raise the issue, just post a reply saying 'BUMP'(y)
I have what sounds like an identical problem but with a Fiat Multipla (2008 1.9JTD). Checked air filter which looks OK. Net says it might be fuel filter. No issues come up on OBD. Any other suggestions?
Thanks a lot.
Thanks a lot.
Suggest doing a new post with exactly the issues you are experiencing, full details of vehicle, what has been done to try and fix and also what diagnostic tool used as some give more detail than others.:)
