Hi all, need some help if possible. I have a 2011 punto evo 1.4 with what I think is a wiring fault somewhere and just wondered if anyone else had had the same issue. Problem I have got is no cranking and imobaliser lock light staying on and no eml light at all. I have replaced the ecu kit from a doner car to rule out the key but the problem is still there. I also can only connect to the airbag ecu with multiscan and it has no dtc's present. Engine ecu will not connect, I have checked fuses and I can't find anything blown so I'm at a bit of a loss with it. Any help would be very much appreciated.
