General wiring pin outs for ECU
IAW 18FD.5Z
IAW 18FD.5Z / BOR 338
PUNTO 1.2 16V ECE FASE 2
46531218 61600.44.00 Z 12V =
So its a Mk1.
I should just be able to join a fiat stilo sensor onto the punto wiring if i can get the wires the right way around, but finding it really hard to determined which the following are:
a 5v ref voltage supply
air temp sensor output
MAP sensor ref ground (black = the easy one)
MAP sensor output
Right, ur kinda screwed there as there is no tech doc for the 18fd, only the 18f which doesn't have the combined map/air temp sensor.
However, autodata says:
14 - 5v out
16 - ground
31 - air temp signal in
32 - map signal in
  • Thanks
Reactions: Dan
Autodata's been around for decades. Before the PC age it was in massive workshop manuals, now of course, it's PC-based and covers pretty much all makes/models in the last 20 years at least. As for where to get it, well, the internet is a wonderful place :p
