The Fiat repair shop suspects that there is a problem in the wiring harness between the ABS unit and the gearbox in my motorhome because the ABS unit is not receiving speed information from the gearbox (my car has a comfortmatic "automatic" gearbox). The gearbox temperature information is also abnormal. This causes the ABS and other fault lights to come on in the instrument cluster, especially in cold weather. If I then run the engine for 15-30 minutes (depending on the outside temperature) and turn it off and then start it again, the warning lights do not stay on and everything works normally. On the other hand, when the air is warm above +20-25c and the car is in a sunny place, the warning lights do not stay on and everything works normally. The car has only been driven 58,000 km and it is a 2013 model.
I would like to ask if anyone has any information on the price/replacement of such a wiring harness or experience with a similar fault?
