Technical Fiat Ducato 230 fault code P040161
Canoeing camper
Nottingham
Fello Ducato owners,
If you have any direct experience of this problem or are an expert in this area, we'd love to hear from you.
We own a 2018 Fiat Ducato 230 Multijet Motorhome, and 2 months ago we had an engine warning light come on, which on diagnostics brought up a P0 40161 code (EGR high pressure valve blocked closed - Signal calculation failure).
We undertook the various suggested actions...….Cleaning additives, long runs(we only use it for these), and had the fault clearer several times, yet it still kept coming back. Eventually we bit the bullet and paid £550 for a new EGR, but within 15mins of having the work done and driving home, it came on again.
Speaking with the mechanic, he tells me the original EGR was very clean and inspection of the joining pipe work showed no build up of carbon deposits, but the solenoid valve was faulty !!!
Has anyone else experienced this issue, and if so what was at the root of the problem, before we continue to throw more money at this frustrating and costly issue ?
Suggestions so far have suggested HP EGR cooler, block DPF or pressure sensor.
Thanks for your feedback 😀
thumbnail
I hardly dare to say it...but that's how it started for me too. My HP EGR was also exchanged due to the error and it still looked very clean. Unfortunately, it quickly turned out that I was affected by the "blocked LP EGR cooler" syndrome. So if your Ducato is a Ducato with 2 EGR valves, it is best to get Multiecuscan, load the template 7 from @theoneandonly and read the Data. Then sent it to theoneandonly...he is the data-god 😁
and read this
and plz check If exaust is sooty,wipe it with a paper towel
greetings Marco
thumbnail
Hi Linda,
It does sound like you may be experiencing the effects of a blocking LPEGR cooler. First question for you to answer, is there any soot in the exhaust? Get a piece of white paper towel and wipe out the exhaust tip and post a pic of the result.
If it is sooty then that is a clear indication the DPF is cracked, and this will allow soot particles to block the LPEGR cooler.
The software Multiecuscan coupled with a Vgate vLinker MS Bluetooth interface is all you need for a very powerful FIAT oriented scan tool.
Below is my suggested parameter template for the 130HP 2.3L dual EGR engine variant. There are other suggested parameter lists, but I would urge you use this one as it is more specific to the issue and your engine.
If you have soot in the exhaust, and you are prepared to learn how to use MES (Multiecuscan), then if you use it to collect the data I can then analyse the data for you after you post the resultant CSV data file.
Let me know if you want to do that, and I will be able to provide further information regarding test procedure once you have obtained MES and learned how to use it.
Link to MES: https://www.multiecuscan.net/
@Canoeing camper
some light reading for you
In there you will find my methodolgy on diagnosis of a blocked LPEGR cooler. As mentioned one test is to wipe the exhaust with a piece of kitchen roll. The next is to get a copy of multiecuscan working on a laptop. The easiest method is via the uk distributor Gendan
There are alternative Adaptors if money is very tight
Once you have Multiecuscan running Please post the csv of your test run. A test should be at least 20 mins from cold (if poss) takes about 10 mins to get to temperature (may not get to temperature before a P0401 is thrown. Please take a screen shot of the error measage. if a P0401 is thrown then clear code and start recording again. I would prefer if you used template 7 as it contains more DPF data but either will confirm initial suspicions.
You may like to add your details to this thread as being a long running thread dedicated to the P0401 twin EGR problems. Some not so light reading, @Fredastaire
@Canoeing camper welcome to the club. I'm the originating person of the 90 plus post that @theoneandonly has invited you to join. He worked together with me from early days.
Your mechanic unfortunately has been misled by the Fiat fault code definition informing him of the LP being at fault, dozens of owners follow this path to replace a perfectly good component. Your mechanic possibly is totally unaware of twin EGR systems.
On the basis that you have a sooty exhaust then at minimum you will need software v28 or 32, to this a new DPF (circa £3500) plus EGR cooler (say £650) plus fitting. On top of this you may just need new injectors and have the inlet manifold and intercooler cleaned.
So far you are only just spotting the tip of the iceberg.
Multiecuscan is the key tool to buy and master to analyse what's needed.
If you can turn the corner on expense your Ducato is good for 300,000 miles.
Do please join us on the main 90 page post.
@theoneandonly @Fredastaire @MarcoWuerttemberger @Canoeing camper
Hello all, I think it would be worthwhile to discuss the parameter preferences that are best suited for diagnosing a blocking LPEGR cooler.
We have two suggested parameter lists before us. There is the original “Template No. 7” created by Theoneandonly, and there is the other refined list which I have suggested to use.
Both use the maximum number of 26 parameters that can be graphed and contain 21 identical parameters. The only difference is the remaining 5 parameters. The parameter list I suggest is based on the original “Template No. 7”, but with refinements that are more suited to the problem at hand.
We are trying to capture data that will help in diagnosing a blocking cooler.
Let us analyse the differences between the two parameter lists to determine the best suitability for the task at hand.
Template 7 includes the Odometer. This has no bearing on any outcome.
It includes Injection Fuel Quantity (Post) which will only be active during a DPF regeneration and not required for this specific test.
It includes the Particle Filter Temperature which is not required as we are already recording two other more important exhaust temperatures – but is specific if we were interested in recording the temperature during a DPF Regeneration.
It includes the Particle Filter Clogging which is not required – we are already measuring the DPF Differential Pressure sensor – it might be of interest if we were recording a DPF regeneration.
It includes the Distance from last DPF Regeneration which has no bearing on the outcome of this specific test.
So, the above 5 parameters are more aimed at capturing data applicable to a DPF Regeneration recording, but not for a blocking cooler.
The 5 parameters that I have replaced them with in the refined list are targeted at the suspected fault – being a blocking LPEGR cooler.
The first one is the Battery Voltage. Note that this is not a measurement of the starter battery at the battery terminals, but the actual supply voltage at the input connector of the ECU. And this is important to look at because if there is a supply or earth cable impedance issue then this parameter will be affected and can have many consequences in any test.
The second is the Turbo Actuator Command – this is absolutely critical to monitor as it has a direct effect on the engine performance.
The third is the Vehicle speed and this is important to help understand during the analysis of the data of the actual vehicle operating conditions during the test run.
The fourth is vital – the LPEGR Target Position, as without this parameter we cannot be sure if the Actual LPEGR valve position is correctly tracking where the ECU is commanding it to be.
The fifth is the Lambda Oxygen Concentration (after DPF). This may not be totally necessary as we are already monitoring the upper one, but it will affect the outcome if it is not correct – so worth adding in as the last of the 26 possible parameters.
To summarise, Template 7 is OK, but includes parameters which are not as well targeted and includes a few parameters which are more suited to the analysis of a DPF Regeneration at the expense of missing some very vital parameters.
The refined parameter list does just that – it refines the targeted parameters to be more specific to the task at hand and improve the likelihood of a successful analysis.
I would like to be clear here, I have no ownership issues, and my pride will certainly not be dinted if my suggestions are howled down or ignored. I am suggesting that it may be time to replace Template7 with the revised Template for future diagnosis purposes. I know from experience that by using the revised template and using a holistic approach to the data analysis, it has proved successful particularly in those more difficult cases where the LPEGR cooler was becoming marginally blocked, but not yet fully blocked.
Before the test is recorded, it is important to look at the Particulate Filter Clogging to make sure it is not approaching 100% as the test results will be invalid if a DPF Regeneration occurs during the test run (DPF Regeneration trigger is 100%).
And as already specified, the test should begin with a cold engine and drive normally until the engine is warm and stabilised – a good 20minutes to half an hour run and with speeds up to the maximum legal on open highway and also try to maintain sections of constant speed and gas pedal opening. After the engine has warmed up it is also important to include a couple of full 100% gas pedal accelerations, say in fourth gear starting from 2,000 RPM to 3,500 RPM. This application of full accelerator pedal will trigger the ECU to close both the HPEGR and LPEGR valve and thus take their influence out of the equation. It is an important part of the test analysis. From experience, the fault is often triggered on a cold engine warming up, with light to medium gas pedal opening.
Note the revised template has two slight variances. The one supplied is for the 130HP engine, there is another (already documented) for the 150HP and 180HP engines as they have the added advantage of having the VGT turbo which includes the measurable feedback servo mechanism.
Up to you John, but I urge you to update your Template 7 to the revised list.
As we all know, there are other parameter lists for recording DPF Regenerations, and more importantly to the Blocking Cooler Syndrome – the Injector Correction Values. They can easily be done as a separate test.
Since I unfortunately have no idea about the data and the analysis, I leave the discussion about the template to the specialists 😁Anything that is helpful in any way should be used.
Luckily I haven't had any problems for 5 months with my Ducato.
Greetings
Marco
Hi Fredastaire,
Thanks for your reply, and concerning feedback. As someone who knows little about vehicle mechanics & the language used, I'm quietly panicking & starting to regret the significant purchase we made less than 18 months ago.
Would it be possible to direct message you in the hope of having a phone conversation to help me understand the territory better. Thanks Ian
Has anyone else experienced this issue, and if so what was at the root of the problem, before we continue to throw more money at this frustrating and costly issue? Just like people carefully research providers for CoolSculpting Vancouver to ensure safe and effective results, it’s worth thoroughly diagnosing the HP EGR cooler, DPF, and pressure sensor before replacing parts.
thumbnail
If the EGR and pipework are clean, the persistent P0 40161 code is often caused by a faulty HP EGR cooler, a pressure sensor issue, or intermittent wiring/solenoid faults. Before replacing more parts, have a detailed diagnostic on the HP EGR cooler, pressure sensors, and related wiring, as these are common culprits even when the EGR valve itself is fine.
@daroya , I'm not sure that you understand our model of Ducato. This entire post is for the Euro 6 twin EGR non adblue variant produced late 2016 through late 2018, coach-built registered later may have the twin EGR chassis that's been in the waiting list.
Our twin EGR needs interrogation using Multiecuscan where you can watch the engine parameters live.
Our twin EGR don't have a HP EGR cooler, yet the LP does, it's hidden out of site sandwiched between the DPF and the engine block.
The LP EGR cooler is usually blocked with soot because the DPF has internally failed and its internal element has cracked, allowing soot through.
The easiest initial survey is to use kitchen towel and wipe out the inside of the exhaust tailpipe, on a good engine the towel will come out nearly spotless. If it comes away sooty then it's indication is a bust DPF.
Do you own a twin EGR non adblue Ducato?.
It's imperative to fully read this multipage post and read the guides that @theoneandonly has written and provided.
