Technical Winter wheel 100hp
Have checked and read lots on here ( great advice)
Still hoping someone can clarify if these will fit on panda 100hp
Our Buy it now offer:
4x steel wheels FIAT PANDA (169) 175/65 R14 82T 4PR Hankook winter
4x Winter tyre Hankook i*cept RS 2 (W452) 175/65 R14 82T 4PR
4x Steel rim 5.5x14.0 ET35
Delivery is free within Mainland UK
Manual says 185/55 14
gr J
The UK 100HP was always fitted with alloys carrying 195-45R15. Whatever is fitted needs to be within a few percent of the same tread circumference. The suggested tyre size URLs will tell you if they are similar enough.
Anything bigger will make the speedo read slow and top gear will feel too tall.
Of course, and thank you
On my toys I have always used winter tyre combo... as narrow as able for rim ... results are outstanding . Obviously in winter it’s just an a to b ... safely ...
I appreciate it needs to be similar rolling circumference .
Struggling to find a winter wheel and tyre choices are very limited at certain sizes
Thanks for all comments and help so far
Ok... bit more of investigation
Will these fit over the callipers on 100hp . Not concerned with radius difference .. minimal on speedo ... and in winter not going to be doing lightspeed
Just about to get a set of punto wheels ... just need to confirm as could be expensive mistake
5.5
14
ET35
It’s the et I’m worried about as manual states et32 on winter wheels
So ... will ET35 be ok ?
3mm might not be enough to notice in practice. You could fit 3mm spacers to correct the ET. Steels usually need shorter bolts, so the spacers might allow you to use the alloy wheel bolts. Check the taper is correct.
