Hi All, my first post as an owner of just a few months - so please bear with me!
I have an 02 plate Punto sporting and all of a sudden the drivers side window has stopped working. I've checked fuses, currently have the door card off (in doing so also found the check strap had sheared in half?!) and having checked on a meter there appears to be power (9V-ish) going each way through to as far as the motor plug when I operate the switch.
I'm thinking of now getting a cheap regulator/motor to plug in to see if this works and my current one is at fault. Is this the logical next step? And if the motor is the issue, is it a pig to replace motor as I believe it comes as a one-piece with regulator - i.e. do I need to remove the glass in order to do so? The window is currently stuck inoperable in the 'up' position. I have read bits and pieces on other threads but all detailed help is more than appreciated.
Many thanks
Mark
Many thanks
Mark
