Technical Window fell down - I opened the panel and found this [pics] - What now?
jlhdasMorahd
Jerusalem
Window fell.
Opened door panel (thx youtube)
found this (see pic)
white plastic broken
silver metal cord spun out of circle tube (whatever)
need new "window regulator/mechanism"? or can I fix?
if need new - where I get one cheap?
broke student here
Thank you!!!!!!!!!!
Model
500
2014
Mileage
66000
Hi was the mechanism loose or did you remove it? Was there any missing bolts?
Most likely it's possible to re install assuming nothing broken ?
All else fails Ebay here"could" at a cost post to you? Postage could be more than the part
I appreciate your response. After some more YouTubing I have found that the white part is the only thing broken, in the point that holds the window (there are 2 notches that the windows "sits" on, and they are broken, so the window simply fell inside the door.
At this point I am wondering if I should just get that white plastic part or the entire mechanism.
But I am not sure they even sell just the white plastic part.
Investigating.
BTW - for the record - and in case anyone comes across this post - THIS HERE is the video that helped me
In the meantime (till I actually get the part) can anyone tell me how do I drive with the WINDOW IN PLACE?
it's currently in the back seat. And the noise and heat is killing me.
Someone suggested I just use tape to tape it to the door but that doesn't sound right and in case of a bump it might fall and break.
Any way to hold it in place CLOSED?
Thanks so much!!
PS - yes, currently driving without a driver's window. :cool:
Put the window in place (+ up) and secure it with two wooden sticks (one closer to the front of the car, the other one closer to the back of the car) cut to size with a narrow groove on the top of the sticks so they will be held in place by the windows itself. EDIT: they need to be put under the window, something like that. The sticks can be smaller, 2 x 2 cm will be enough.
The plastic part should be available as a separate part. It's not listed as a spare, but I've found it on ebay:
Double check the model / year before the purchase :)
Hiim in the same boat - did you manage to fit just the white plastic bit if so how hard was it or did you get the whole bit?
Cheers :)
Cheers :)
hi.
so, i found out you can order just the plastic part on ebay for cheap.
unfortunately, i did not have time for that as i needed to close the window :)
went to a guy that was reasonably priced, he had the plastic part (without the electric motor of course - which is more costly).
i actually tried to do it myself - it's possible, but the cables got stuck in the mechanism and i couldn't get them out. so i gave up.
he changed the plastic part, rewired the wired, and installed it in the door.
it works.
hope this help!!!
