General Window falls open
Ross1979
Hi, my passenger window falls open for some reason. The electric switch doesn't seem to do anything either.
I slide the window by hand up to the top but after an hour or so of driving or going over a speed bump it starts to open very slightly.
I want to have a look at it myself but not too sure what i'm looking for? I guess it'll be pretty obvious once I get the panel off of the door (will it???). Also is there anything that will block access to what i need to see??
Varazdin,Croatia
When you press the switch-do you hear motor buzzzing?
Maybe just window glass is detached from the lifting mechanizm .
Anyway you need to get panel off the door and you will see
willieboy
Put a towl on it
Hindhead
sounds like your windows just slipped off the runners mate try and hold it there with something untill you can fix it
rallycinq
Autotest Special
Lake District....Moist
The mechanism should slide on runners attached to the window glass. With luck it will have come off the runners, but I have seen the runners corrode away to nothing. If they have corroded, get a complete replacement window, you can't get the runners off easily, and they don't stick to well when refitting.
If the runner has failed then, if the mechanism is working, wind it up under the window glass, and disconnect the motor until you can get a new one.
The window comes out through the top, you need to, carefully, remove the window bottom rubbers.
