not like that it wont. it will need to be welded onto the current system. the uno 45 zorsts have a long pipe that connects to the centre section. i dont know how the uno turbo zorst is though. but it wont fit straight on.
It might fit. You would have to cut the back box off though, where it joins the curved part that goes over the rear axle and joins the long centre section. The standard Uno 45 back box comes with the curved section and is in one piece.
The only other problem is that the diameter of the turbo back box join and the 45's are probably different, so I'm pretty sure the turbo back box will be too big to slip on the 45's pipe.
But with a bit of time and welding you can make anything fit!
This will fit, but not straight on. You need to cut the existing backbox off at a certain point. Buy and adapter that expands to the spcified sizes of the existing pipe, which is 1,5" to the new backbox which I don't know the size of. Two exhaust clamps is needed to fit the new box and existing pipe to the new adapter. There is popbably a word that will replace my word for adapter, but I don't know it...
