- Joined
- Dec 10, 2007
- Messages
- 257
- Points
- 87
Hi
I have two Multiplas that need new timing belts. As recommended I would like to replace the water pump at the same time. I don't want to spend a lot of money yet I dont want to have to redo the belt should the wp bearing on a cheapie wear out it disintegrate prematurely.
You can search on ebay but sellers set out to confuse. Most use at best 'misleaders' like 'OE quality', or 'marches OE', or use their own reference 'BOLK' which is their own made-up trade name to suggest German quality, or 'Manufacturer: FIAT' which does not refer to the manufacturer of the actual water pump. Others use a part reference code which a google search only throws up their own ebay offerings. If you ask them where their wp is made they will say something like it comes from FAI but they dont know where it is made. Most quote all the upmarket make references but only as cross-references.
If you go to Shop4parts it says their wp is made by Bugati
Ir shouldn't be this difficult to find a cheap OE approved waterpump!
Any recommendations or comments?
