Which ELM327 for Bravo
Is the right interface for Fiat Bravo that worked together with Fiat-ECU-Scan with which engine, climate, airbags, etc. as well as monitor the parameters and erase mistakes can work? is there something similar in Bluetooth version?
http://www.ebay.com/itm/NEW-VAG-KKL...:g:o2EAAOSw3ydVsH7t&item=111724724486&vxp=mtr
look on the MultiECUScan website to see what you need to connect to YOUR CAR, :)
the one in your link is switchable and KKL / vagcom:confused:
you've asked about ELM..look at my post in the TECH section;)
Thank you,
I just want to by on e-bay proper interface that I can use for things I explained in my first post. So what to look for on ebay? If you can send me a link, it would be great. I prefer bluetooth, but if there isn't any of it USB is fine too. I have Fiat Bravo '07 1.9 Multijet 16V, but that manual on multiecuscan page is quite confusing for this type of car?
So it would be this:
This interface: http://www.ebay.com/itm/Auto-V2-1-I...708511?hash=item2eee0397df:g:Jy0AAOSwKfVXD8wb
+ this A1 adapter kable:
http://www.ebay.com/itm/Diagnose-Ad...256570?hash=item3f505daefa:g:H7UAAOSwDk5ULac~
Thanx
I got that cable u posted in the first post. I tried it to set up but i constantly get errors and cant connect to ecu, but everything is fine with the connection. I have fiat bravo 198 2007 1.9 multijet 16v.
I want to buy Elm327 for bluetooth, but dont know which. Did anyone got the Elm and what version because i want to buy it from aliexpres. Thx
Thanx
Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9, 2.4) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELMOBDKey
Bosch ABS 8 |INFO|DTC|DTC EX|PRM|ACT| KL 1ELM 1OBDKey 1 A1
Bosch ABS 8 ASR |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL 1ELM 1OBDKey 1 A1
Bosch ABS 8 VDC |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL 1ELM 1OBDKey 1 A1
CONTINENTAL Airbag (PROXI) |INFO|DTC|DTC EX|PRM| ELMOBDKey
SIEMENS MY06 Airbag |INFO|DTC|DTC EX|PRM|ACT| ELMOBDKey
TRW Electric Power Steering (3) |INFO|DTC|PRM|ADJ| KL 9ELM 9OBDKey 9 A1
Service Interval Reset |INFO|ADJ| ELMOBDKey
Connect (NAV) Marelli |INFO|DTC|PRM|ACT|ADJ| ELMOBDKey
Convergence Lauberhorn C1 (Blue&Me Nav) |INFO|DTC| ELMOBDKey
Convergence Marelli/Microsoft (Blue&Me) |INFO|DTC| ELMOBDKey
Convergence Marelli/Microsoft C3 (Blue&Me Nav) |INFO|DTC| ELMOBDKey
Instrument Panel Marelli |INFO|DTC|PRM|ACT|ADJ| ELMOBDKey
Radio Nav Marelli |INFO|DTC|PRM|ACT| ELMOBDKey
Body Computer Marelli (198) |INFO|DTC|PRM|ACT|ADJ| ELMOBDKey
CAN Info |INFO| ELMOBDKey
CAN Monitor / Vehicle Settings |DTC|PRM|ADJ|
CAN Setup / PROXI Alignment Procedure |INFO|ADJ| ELMOBDKey
Marelli climate control |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMOBDKey
Litronic XENON headlamp (left) |INFO|DTC|PRM|ACT|ADJ| KL 12ELM 12OBDKey 12 A1
Litronic XENON headlamp (right) |INFO|DTC|PRM|ACT| KL 12ELM 12OBDKey 12 A1
Driver's Seat LEAR |INFO|DTC| ELMOBDKey
Parking Control BOSCH |INFO|DTC|PRM|ADJ| ELMOBDKey
Passenger's Seat LEAR |INFO|DTC| ELMOBDKey
Tire Pressure Control (TPMS) TRW |INFO|DTC|DTC EX|PRM|ACT|ADJ| A4
EVERY line has ELM OBDKey,
so an ELM is the better cable type,
there are some KL1, 9, 12 ,etc
so there are SOME elements your VAGCOM KKL cable SHOULD connect to
are you using the coloured adaptor leads..??
Charlie
As i wrote previously, I understand that ELM is better so I asked which ELM to by from ebay (that works) and as I understood, i need just A1 adapter cable (green).
So is there any recommendation for ELM that works.
Greetings
ELM has arrive and it works with almost all phone/tablet diagnostic software.
But when I try to connect it to multiecuscan, it said this:
Please connect the interface to a car!
Scanning ...
ELM 327 v1.3+ (Bluetooth) interface found at port COM5, speed 115200bps
WARNING: This interface is not compatible with ELM 327 1.3! Will not connect to any CAN module.
And it can't, I try everything. In attach there is photo of ELM.
