You said that you have the speaker cable running down one side of the car and the power wires running down the other. Try running the speaker cable down the centre of the car, thats what I had to do to get rid of my interference. I had PHONO leads down one side and power/remote down the other and my speaker cables didn't like being next to either. Obviously this will be different for you as you have no phono leads.
Another thing to check is that your wires aren't touching any metal part of the car, make sure the plastic insulation didn't get torn when it was fed through any gaps......this can cause shorts/interference.
The only other thing is the Gain, have your ignition on, and the stereo and lower the gain until the interfence stops. If it stops eventually thats the problem, if not it could be any of the afore mentioned problems.
As mentioned HI-Level inputs aren't great, RCA's are better but if you use one correctly you still shouldn't get interference. I think Idaho uses a HI-LINE input as he has the standard HU amped but he gets no interference so thats probably not the problem.
Also what speakers are they? You say they are components (which means a seperate woofer and tweeter) but you say further down that you havn't installed your crossovers. Surely all the wrong frequencies are being sent to each driver. If they are indeed comps then you NEED the crossovers.
