In the UK Compomotive Motorsport wheels are available directly, or from a network of appointed dealers who keep selected stocks of Compomotive wheels.
.Compomotive’s experience sales staff will be only too happy to advise you of the exact fitments for your vehicle to create the best looks and performance. Should you require fitment or dealer information please email us at [email protected].
so no shops stock em ?
errr first google search for 'Compomotive ML's' gets this:
http://www.performancealloys.com/compomotive_alloy_wheels.asp
why not just get quotes from CM and compare to their prices.
all they will do is take your order and pass it onto CM
Under wheel description:
"Available in all fitments. Which I guess means they will drill holes to suit your PCD. The classic competition wheel, in FIA approved sizes for use in all forms of road and motorsport.Offset Range: ET-38 to ET+40."
Cinq = ET29 so you will need minimum of 9mm hubcentric spacers.
Sizes that fit cinq are 13x5.5, 13x6, 14x5.5, maybe 14x6
If you get them made in correct ET then you will not need any spacers that's the point of having the range from ET-38 to ET=40, you specify when ordering.
So if going for a 13X5.5 same size as original get them made up in ET29 to match exactly what Fiat did leaving 3mm spacers on front, if going different size then ET will need to be changed. There may also be issues with brake calliper clearance as I belive that Ghost had issues, and therefore may need to go to say a ET20 or even less to ensure clearance.
I would on account of this be inclined to pick up the phone and actually speak to someone and get all the answers you need to furnish your knowledege before ordering, not sending e-mails back and forth this achieves nothing very quickly.
Aaron.
eeeeew bad pic
may mail them a better pic to use lmao
The ml's generally need a 10mm spacer to clear caliper anyway...
Mine are 4x98 6x13 with a ET of 26, perfect on the backbut the front needed 10mm spacers to clear the caliper
thanks.
Got a email back.. he reckons £412 with UK mainland postage ?
what you reckon ? worth the money ?
