Technical where is indicator relay located 2005 Ducato
hillraid
Anyone tell me/show me picture/diagram to let me know where the indicator relay is located on my 2005 Ducato motorhome. Im aware there are 3 fuseboxes .The indicators dont work but hazard lights are not affected as covered seemingly by separate relay. Many thanks in advance.
If Iv seen this prob before few year ago if my memory serves me the hazard switch is faulty causing the stalk not to work even though hazards work ,can you get a cheap hazard switch unit to try
Hazard switch is built into a unit with openframe relays soldered to the pcb it has a really wimpy pcb connector on it so I would start with cleaning that with decent contact cleaner you need to take out the radio to access it.
ive got nearly the same problem but i dont have either the hazards or indicators, ive put a new switch block in and still nothing,,,,, so any advice would be handy .....
Has anyone solved the problem of no indicators and no hazards working on a 2006 fiat ducato 2.8,
Where is the flasher unit / Ralay fitted,is it part of the hazard switch or in one of the fuse boxes or elsewhere.
A 2006 2.8jtd is an x244 model, (2002 - 2006). On the x244 the hazard flashers and direction indicators are controlled by the "Switch Control Panel" (H090). This is a typical "black box" with no information about its internal workings, but the internal logic does affect many items. The panel is located at the rear of the auxilliary switches below the radio, which must be removed for access.
See attached annoted copy of eLearn diagram E2020, my own table of switch control panel connections, and colour code translation.
  • eLearn E2020 Direction Indicators.pdf
  • H090 Switch Control Panel.pdf
  • Fiat Wiring Colour Codes.pdf
Hi
I am new on here and hope someone can help me
We have a fiat ducato 2004 2.8jtd motorhome x244
And the indicators and hazard lights have stopped working.
The fuse 53 is okay, and all other lighting etc is okay.
I have noticed the power to the rear light clusters is only 10.7 volts.
One other thing i have noticed is the toad immobiliser flashes the indicator lights but not the remote (though it works)
Has anyone any advice on what is the problem/fix?
If you have read my preceeding post you should be able to download the necessary diagrams. Th x244 "switch control panel" is still a "black box". I can only suggest checking all fuses mentioned on my list of connections for the switch control panel (H090), and any other fuses deemed appropriate.
I have fixed it!!
When taking apart the radio unit to find the h090 switch control unit, i freed off the hazard light switch which was stuck half in half out and et voila indicators and hazards work!!
So it was the hazard switch.
