Grande Punto When idle car sort of shivers ? Like it's cold
Kylethomas94
When just parked up and my engine running every few seconds the car will sort of Shake as if it's cold and needs a blanket ?
It's not tensioner or anything it's been serviced and cambelt. Just done so ?
Is it just that it's what these cars do or ?
Haha she gets treated well just serviced and got cambelt
So I'm now thinking remap etc buh dunno if I wanna go to 160 ish or get bigger turbo and then remap etc
Clean the throttle body......
do throttle relearn...
if that fails to work
remove air box again
fill plug caps / coil pack plugs with Silicone grease (IT MUST BE SILICONE ANYTHING ELSE WILL DISTROY THE HT LEADS) and blather leads in holts damp start.......
(assuming petrol engine 1.2 / 1.4 8v) }}
I have 1.4 tjet it's just been serviced and done it before service
My air con always off and even wen heaters are on or off it happens just checking it's not a big problem cos thinking of spending some money on remap etc
If it's any consolation I have a 1.4 T-jet 120 Bravo and it's does the same thing. When parked or still you get a very slight rumble/vibration that you can barely feel. But it only happens every couple of seconds. If you watch the rev counter it tends to sway ever so slightly as it happens. Almost like its on the verge of stalling (obviously not quite that severe). I don't understand why it does it. Doesn't see to be an issue though.
