General Wheel Bolts sizes - for GP 1.4 TJET
Hey Guys,
Soory for the long absence, bought a new phone which is android 9 and it seems i cannot get the Fiat forum app on my phone, so harder to check in.
But does anyone know the specifications for the GP 1.4 Tjet (OEM). I have missed placed a bolt and need to replace. I am measuring my other botls and get 17mm socket / 1.5mm thread pitch / 12mm thread width / Approx 20 - 22mm thread length. The thread length is causing me issues as it is not 100% clear were the thread starts.
I am search on ebay using my reg and it is giving me 17mm x 1.5m x 12mm x 60 degree cone taper x26mm thread length. I am struggling with the cone taper of my original bolt + also the the thread length of their 26mm vs my 20-22mm
Thanks in advance
I would have thought the wheel bolts would be all the same sizes...BUT if in doubt ask a Fiat dealer....at least I would.
Hey no they are not all the same, I mean i guess a few mm added to the thread would not harm, but if your like me and u like to use oem where possible, because a single knock will leave you paranoid the details are as follows:
Length [mm]:47.5
Outer thread [mm]:M12 x 1.5
Outer Diameter: [mm]:22.3
Spanner Size:17mm
Bolt Head-/Nut Desig - Male Hex
Wheel Fastening Conical Seat F
The fiat product OEM product code is: 51732885
GSF do them for vauxhall, product code: 451GM0010
Added note a Vauxhall Corsa D 1.2 2013 plate uses exactly the same size, so you may find it cheaper going through vauxhall, or looking on ebay for vauxhall instead of fiat.
I had to buy a full set for my punto as a garage got a bit giddy with the whizzy gun.
I bought these from GSF:
https://www.gsfcarparts.com/451gm0010
Exactly the same as the original. Although it doesn’t say on the website they supplied genuine Febi bolts which was a nice touch.
Hope this helps.
Found this old pic of mine..
Old and new FIAT locking kits
Hope this helps.
you are correct mate, those are the ones, the come up for vauxhall but I can assure you that they are also for fiat, compared my bolt to my wifes corsa D and exactly the same for anyone else interested.
