General  wheel and specs FAQ's
Unconfirmed list of wheels the same fitting as a croma
ALFA ROMEO 159 (NOT V6) 05>
ALFA ROMEO 159 SPORTWAGON ( NOT V6) 05>
ALFA ROMEO BRERA (2.2 MODELS ONLY) 05>
CADILLAC BLS 07>
CADILLAC BLS WAGON 07>
FIAT CROMA 05>
SAAB 9-2 05>
SAAB 9-3 07>
SAAB 9-3 CABRIO 07>
SAAB 9-3 96-07
SAAB 9-3 CABRIO 96-07
SAAB 9-5 05>
SAAB 9-5 97-05
SAAB 9-5 CABRIO
VAUXHALL ASTRA H (5 STUD) 04>
VAUXHALL ASTRA H COUPE (5 STUD) 05>
VAUXHALL ASTRA G (5 STUD) 98-04
VAUXHALL ASTRA G COUPE (5 STUD) 00-04
VAUXHALL CALIBRA (5 STUD)
VAUXHALL CORSA D (5 STUD) 06>
VAUXHALL CORSA C (5 STUD) 03-06
VAUXHALL CORSA COMBO (5 STUD) 06>
VAUXHALL MERIVA (5 STUD)
VAUXHALL OMEGA
VAUXHALL SIGNUM 03>
VAUXHALL VECTRA C 02>
VAUXHALL VECTRA B (5 STUD) 95-02
VAUXHALL ZAFIRA 05>
VAUXHALL ZAFIRA 99-05
Is there anyone to confirm that 6.5Jx16 ET41 rims are compatible with Croma 2.4 or not? I am asking this, because the owner handbook says that the compatible rims for 2.4 engine are only 17" and 18". I am considering buying 16" rims for winter tires.
And what about the offset (ET)? Could it be slightly different, because there are much more Opel's rims on our market and these are usually with different offset?
Thanks in advance!
i got a second set of aloys in 17" for winter off ebay, they were only £60
a few mm off set it usually ok, if you are going for thinner tyres should be ok, if the off set is less wheels stick out more, if off set is greater wheels sit further in.
if you can test fit wheels before buying.
They might not fit at all, but even if they do fit they may restrict air flow around the brakes, which could lead to over heating. Personally I would look for some 17s as they should fit ok plus 17" tyres are generally cheaper than 16s.
