Whats this part called
Bistray1
Working on a 2007 1.4 sport, its had a slight engine leak, took the airfilter box off and there was a load of dried oil on top of the block, it appeared to be coming from the part in the picture, dont know what it is, there was no seal around it. Ive circled on the block where it came from, any help appreciated
Apologies for my belated reply.
That's simply a bolt that once removed, it gives access to the bolts securing the "valve head" to the engine head. Otherwise, it is simply a bolt that is useful for other Fiat blocks.
Nothing special really but it should have an o-ring, hence the leak.
I would try to get an o-ring from a motors factory (or online), albeit the original one is quite thin.
Double check if the original o-ring is somehow still stuck to the top of the block.
