JTD Battery Size & Spec
Hi -
Battery on my 04 JTD is weakening, will need replacement soon. Current OEM unit is approx 240mm L, 175mm W, 190mm H. This leaves some unused space in the battery compartment, and I'd like to use that space to add some 'winter morning' margin.
Standard replacement appears to be the 075 (210mm L, 175mm W, 190mm H), but that's smaller than the OEM unit (an 027?). Seems daft to leave empty space, so I'd like to squeeze in a 096 instead (278mm L, 175mm W, 190mm H) - approx 10AH & 100CCA more than the 075.
Can anyone save me the hassle of removing the battery to measure up? It looks like the 096 will squeeze in on the L dimension, but has anyone tried this?
Thanks in advance!
Hi -
Thanks in advance!
