what sparks u use?
what sparks u use?
Re: Re: Re: Re: Re: Re: Re: Re: Re: what sparks u use?
It will not work without an electrode.
Was that comment OK with you all?
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: what sparks u use?
Dunno, would be interesting to try some. My current set are going off so need some new ones very soon.
Website?
Its called a surface discharge plug, used by highly tuned 2 strokes as they don't foul (big problem on 2 strokes) BUT they do require the HT system to be tip-top. Any issues with your HT system and you've got a non-starter.
i think dutch was refering to the 2, 3 or 4 electrodes that some have (bosch for instance).
you should have noticed this if you looked at the pictures.
i posted one of them so you could see this.
I've been running these for 4 years now, no probs!
Copy/paste:
"Multispark-plugs that increase engine power. Two auxiliary electrodes attached at the top of the isolator use special patented technology allowing simultaneous spark-over of two surfaces and one airborne spark for each ignition system pulse. Each spark can flash along the whole perimeter of the auxiliary electrode _(360°)_. The spark gap is deep inside the combustion chamber and improves the initial spread of flame front. The number of sparks and sufficient distance between them decreases the likelihood of an imperfect mixture ignition in the combustion chamber, increases combustion velocity and engine power.."
http://www.brisk.cz
Dunno if these are being sold in the UK...
Tom you're right!!!
"surface discharge plug"
All I can say is: they're excellent plugs!!
Peter
i've never come across them, someone will know if they're available here.
Outboard engines have been using them for years.
now now rog, your taking this far toO seriously, it's all a bit of fun!
Alan, did i detect a hint of sarcasm in your last post?
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: what sparks u use?
i guess i'm just a twisted sadistic bastard who enjoys the dabate as much as rog does!
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: what sparks u use?
LOL ;)
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: what sparks u use?
dabate? This alcohol is going to my head! Sounds like i'm from de islands man!
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: what sparks u use?
its not the alcohol going to your head!
say no more :)
i've just sent an email to Brisk, i'll let you know if there's an outlet here in the uk.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: what sparks u use?
In the US they have this Bosch Platinum + 4. It is almost the same construction as Bosch Super 4, but with Platinum tips. And also there is another product from Bosch called Bosch Super Plus, uses different type of material.
Gurjit, what is your NGK model that you are using.
Thanks,
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: what sparks u use?
Champion Eons (£19.99 for four).
Got sold on the Marketing cack and just thought buy them. Changed them as part of oil (GTX Magnatec) and air filter (Champion version for Factory Air filter box) service and now the car sings. Seems to have a much fatter note from the engine, it revs better from off and seems to free-run much better. Could be just because it badly needed the service after doing 12k miles in ten months.
Marko
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: what sparks u use?
y'know i emailed brisk last night to see if there is a uk outlet for these sparkplugs... well this is the response i got.........
This Message was undeliverable due to the following reason:
Each of the following recipients was rejected by a remote mail server.
The reasons given by the server are included to help you determine why
each recipient was rejected.
Recipient:
Reason: 5.1.1 ... User unknown
sorry guys, i did try.
NGK
I don't remember the model number. I got it from Sykt. Glory, Jalan Ipoh.
Now it's funny you should mention this (as I begin to eat my words) as I used to the owner of a very fast two stroke (in the days of my youth) and I seem to recall some shop trying to sell me these ridiculously expensive plugs.
I am a tool.
Re: NGK
Thought i'd have a look at that web site too.
I got the e-mail address and phone no.
craig said the e-mail won't work so i might try the phone (while i'm at work of course).
I really need to get my HT system up to scratch anyway as i need a much better spark (will only start on petrol lately so the spark must be crap.)
So i'm interested in these plugs or anything that will give me the best spark possible.
P.S.Tom can you tell me what size SS pipe i would need to get for an induction pipe (i might be able to get my hands on a bit)1.6 16v 1996 Brava
Thanks.
Foreign distributors:
Select country...
Great Britain
zapadni skupina - division West
tel.: 00420 / 381 492 477
fax.: 00420 / 381 281 036
e-mail: [email protected]
Rab :)
K
2
1K
Dark Lurker
T
4
732
Insomnia
I
C
2
414
Robin
R
M
1
675
M
