mattwick92
- Joined
- Nov 23, 2015
- Messages
- 77
- Points
- 71
Just wondering because every time I use eurocarparts they give me the wrong ones.
buy them from shop4parts instead better service tooJust wondering because every time I use eurocarparts they give me the wrong ones.
Thanks![]()
DCPR7E-N-10 are the correct NGK code fitted from the factory
Eurocarparts part number is 408650010
If you look at fitment detail it has "from engine no- 2533529" on the 10 reg these will be correct for your car.
I have recently changed mine also a 10 reg, eurocarparts are a pain because they don't tell you on the description that they are DCPR7E-N-10 but that's what they are.
A better idea is to fit iridium plugs; NGK DCPR7EIX are the ones you need. They're a direct replacement for the DCPR7E-N-10 and far better quality.
They'll easily last at least 60,000 miles without needing any attention whatsoever. I've the exact same car as you and have used them for the past 10 years, with no issues whatsoever.
The original DCPR7E-N-10's were well past their best at 6k.
In over 30 years of using NGK plugs, I have never seen a set last only 6,000 miles, Usual changing at 20,000 but they are good for well beyond that.A better idea is to fit iridium plugs; NGK DCPR7EIX are the ones you need. They're a direct replacement for the DCPR7E-N-10 and far better quality.
We did plugs for the 1.2 FIRE to death about eight years ago; the thread is here.
I've used the DCPR7EIX in both the 500 and the Panda.
The 500 started running slightly lumpy when cold from about 6000 miles; fitting iridiums cured it immediately, never to return. When I pulled the plugs, you could see the spark was tracking all over the centre electrode; picture in this post.
Copper core plugs are 50yr old technology; iridium alternatives work consistently for much longer and cope better with the ethanol content of modern fuels. If Fiat had spent an extra £10 on fitting decent plugs in the factory, they could have reduced the cost of the 2yr service ( at franchised dealer prices) by at least £100.
