Styling What parts will fit
gaz12
Hi all just bought a ciq for a run around but needs a new seat,would the seats from a sei fit with no mods???
Also what other parts will fit without any mods??
thanks in advance gaz.
Bolted a set of Sei seats in my Cinq this weekend. Straight in, however i swear they're slightly higher.
Rear seats are meant to go in, but the bolt holes woudn't line up so i left them at the breakers.
So the rear bench seat fits just the mounts which need sortin??
Thanks guys would front bumper fit i know grasping at straws here ,also anyone fitted HIDs as might fit me old ones of me other motor if they are the same fitment.
All the bottom mounts go straight in, the only ones that are slightly different are the top one where the catches are but it is quite easy make them fit. You need to get all the relevant mounting brackets when you get the seats.
Took me about an hour or so to swap the seats over in total
Think the seats may allready be off so dont know if ill b able to get mounts,can u upload a pic of what i need as i dont want to buy and only have the front seats fitted!!
normally i'd nip out with my camera and get them for you but I did my knee in pushing a Lotus off a car transporter last night so am on crutches:eek:
But i'll do my best to desrible them if they are the split rear seats then there is a small hinge that goes at the front. A large almost strange j shaped bracket that fastens at the back and actually goes down into the spare wheel well. you also need the two rear latches that sit at the front of the parcel shelf. The Sei catches are built into the seat the opposite way to the cinq so you have to remove the cinq catches and replace then with the Sei latch
Thats great i know what u mean so hopefully will b able to source these bits,how much higher are the seats when fitted over OE ones as me knees are close to the wheel now??
Maybe a cm or two higher. Just feel higher. Not bad, but i would of hunted down cinq seats had i know.
